Remotek & Merten Universal Remotes
Has anyone ever tried to connect a Remotek or Merten Universal Remote to the Vera2? Are they capable of running Vera-Scenes?
Remotek:
http://www.remotec.com.hk/zaspx/product_content.aspx?aboutno=9&subaboutno=22&main=f
http://www.zwave4u.com/products/de/Z-Wave-Steuerungen/Fernbedienungen/Remotek-Universalfernbedienung.html
Merten:
http://www.zwave4u.com/products/de/Z-Wave-Steuerungen/Fernbedienungen/CONNECT-Universalfunkfernbedienung.html
EDIT: Does not work as it seems: http://www.zwave4u.com/products/de/Z-Wave-Steuerungen/Fernbedienungen/CONNECT-Universalfunkfernbedienung.html
I can’t find anything here in the forums nor in the wiki.
The REM_ZURC550 is quite a nice - and large :slight_smile: - piece of hardware. MiOS doesn’t support adding scenes to the remote via the ‘Scenes’ tab, but you can define separate scenes that can be linked to the ZURC via ‘Events’ → ‘A scene is activated’ → ‘Which scene number’ → 1…9
Limitations:
[tt]http://bugs.micasaverde.com/view.php?id=1394[/tt]
[tt]http://bugs.micasaverde.com/view.php?id=1395[/tt]
The merten remote is not compatible with MiOS:
[tt]http://wiki.micasaverde.com/index.php/ZWave_Add_Controller#Unsupported_.2F_Partially_supported_controllers.2Fgateways[/tt]
Thanks for your feedback. Why did you have to talk about the size, now I am not sure if I want it anymore :cry: It’s huge that thing (60 x 240 x 29m), you could use it for self defense too!
Has anyone tried the Remotek Z-URC-300:
http://www.remotec.com.hk/zaspx/product_content.aspx?aboutno=9&subaboutno=33&main=f
