Hello!
Anyone tried this with Thosiba RAS 10? cannot get it to function with the settings for Thosiba in the manual :-[.
Hello!
nervermind, had I read the manuall right the first time this hadn’t been an issue. I typed the parameter wrong.
So did it work ? and what UI are you using? UI5 is probably the best if you are gonna experiment the parameters.
Yes I know, i’m on Ui7 the latest upgrade now on both my controllers. It worked perfect, I only had to change parameter 27 according to the code list, in my case I got a hit on my first try and it was 71. If that didn’t work I was suppose to try the next on the list and so on until you find the right one.
