I have a Remotec ZTS 110 Thermostat, Can someone tell me how to have the theromstat react to the set point with the closest allowed tolerance . It currently is set to 1? which means if my setpoint is 68? thermostat will not turn on until 67 and then turn off until 69. Have veralite runnin UI7
You have the possibility to change it to 0.5. In fact in celcius.
See my post over yours, I’m looking to flat this swing configuration.
