Remotec ZRC100
Hello. I am using Vera 2 as my Primary controller for Fibaro Double Relay Swiches FGS221. Its works fine.
Recently i purchased a Remotex ZRC Remote to act as my Secondary Controller. But i am facing certain issues
  1. FGS221 controls 2 Light switches, which can be seen in the devices list of ZRC100. But when i am creating scene on the remote, it doesn’t support me to add the 2nd Switch of FGS221.
  2. How do i add the scenes on MIOS/Vera directly to the remote? without the need to configuring each scenes individually. Is the scene learning possible between Vera & ZRC100.
And i forgot to mention that after i completed the leaning mode which help me get all the devices directly on ZRC, the MIOS tab of ZRC100 shows the status as "Waiting for wakeup to configure "
Can anyone help exactly what it is?
I could add the scenes to my ZRC100 remote controller using the Events>Add event in each scene. And its working. But there is delay of 5-10seconds in the scene execution.
What can be the reason for it?
Hi - I don’t have any relay switches but I do have a ZRC100 that I am trying to get included into my Vera. What section of the manual are you following to get as far as you did, since I am not getting very far at all.
I have gone through multiple post of this forum & some searched online. You have to add ZRC-100 as ‘Battery Operated Z-wave device’ on your Vera dashboard which you will find in ‘Add/Remove Devices’ .
Thanks for the reply. I don’t have an Add/Remove Devices menu on my Vera 3 dashboard. I only have Devices->Add Devices. I’ve tried various options under there including “Advanced Z-Wave Devices” and then add as secondary controller. I have some of the GE remotes also. Remotes are one of the few areas for which I seem to have very poor luck with Vera.
I am gonna try soon on to add ZRC100 on my Vera 3 as secondary controller. Once done will update you.
