Remotec ZFM-80
Hello,
I’m try to determine when someone is in bed. I’m looking into pressure sensitive “bed” switches and thinking about attaching one to a Remotec ZFM-80’s external switch. Can I configure the Vera Edge check the state of the external switch?
Any other ideas for bed switches are welcome.
Thanks,
Howie
[quote=“aviddv1, post:1, topic:186707”]thinking about attaching one to a Remotec ZFM-80’s external switch. Can I configure the Vera Edge check the state of the external switch?[/quote]No. There is no effective way to check the state of the external switch.
You would probably be better served by attaching your pressure pad switch to a door/window sensor, such as the Schlage RS100HC Door and Window Sensor which has contacts for an external switch/sensor, or to a Fibaro universal sensor. The universal sensor is pretty much the same as the guts of a Fibaro door/window sensor.
Thanks for heads up. At this point, I don’t even know if the pad is a switch itself or if it just goes high or low and the chip detects the voltage. We’ll see…
