Hello guys,
I want to control my Toro irrigation Timers (2 of them) via Z-wave. Reading this thread here http://forum.micasaverde.com/index.php/topic,14722.0.html he accomplished that goal with an external power supply and a relay switch. After some research I found this:
http://www.zwaveproducts.com/layout/manuals/ZFM-80US.pdf
I could install this in the wall and route the white wires from my Toro control timers through that baby and then control on/off of my pumps via Vera assuming I align the Vera clock and the Toro timers clocks. I use regular power from the outlet to power the Dry Contact relay and I use Z-wave to control on/off. I don’t care that this costs $48 vs $21 bucks from the previous thread outlines above but it will looks much cleaner if I find a way to cover the white cables from my Toro’s.
Can anybody confirm that my thinking will work from a technical perspective?
Can I connect both white Toro cables into one relay or do I have to buy 2 relay’s as I have 2 Toros (front yard and backyard)?
Thanks in advance for any feedback.
