Hello. Can anyone make a diagnotic suggestion? I have a remotely located Vera2 unit. It has worked fine for a month. Since 10/14 I have not been able to log into it remotely with UI4. I just get the message box “data not loading?”. I also notice the system stopped making daily backups on 10/14. Is there a way to determine if the problem is in the unit or in the Mios server?
I also had some quirky behavior in the system on 10/14 where a notification I was supposed to receive by email didn’t arrive due to a message send “failure”. The log is captured below. This was working a few days earlier. Any suggestions?
Thanks.
xxxxx dnarba guest@comcast.net
E
2010-10-14 14:47:58 Failure
2010-10-14 14:48:31 Failure
2010-10-14 14:48:58 Failure
2010-10-14 14:49:25 Failure
2010-10-14 14:49:48 Failure
2010-10-14 14:50:05 Failure
