Remote Vera "Toggle Navigation" button...
Tried to log into my remote UI7 VeraPlus v1.7.2935 via home.getvera.com, as usual.
Only getting the attached screen shot, with. “Toggle Naviagtion” button that’s not operable.
Edit: the redirect URL is https://vera-us-oem-relay41.mios.com/www/1.7.934-en/?PK_Device=XXXXXXX
The Vera is up and running and accessible via the official Vera app (which doesn’t allow you to reboot the box, btw…).
Anyone else seeing this?
.//A.
Did you ever figured this out? I’m having the same issue. I have to reboot this box like every 2 days or I can’t use it. Sometimes will not load the controller page after login and how it has the problem you have and power cycling is not solving it. I’m so fed up with this controller…
