Remote Log File Access
I can view the Vera2 logfiles with ssh over the local network, but often, I’m at a remote location, and would like to view the logs. How is it possible to view the logs from a remote location? Does this require port-mapping ssh to the VERA2 on the router? or is there a web based interface in UI4 to the logfiles?
AFAIK, there is no access to the log files via the GUI.
You could set up a scene with some Lua code, which ftpputs the logfiles to a ftp server of your choice …
