Anyone else having trouble recently trying to access Vera remotely. Both my HomeBuddy app and connecting from mios.com no longer work. I get a “Data Not Loading?” error and cannot see my vera.
Any suggestions?
Any suggestions?
me too…
I am able to control my vera fine via remote access using my android app. Home Buddy uses the same url’s for remote access. Could be a momentary glitch?
[quote=“tamacher, post:1, topic:169833”]Anyone else having trouble recently trying to access Vera remotely. Both my HomeBuddy app and connecting from mios.com no longer work. I get a “Data Not Loading?” error and cannot see my vera.
Any suggestions?[/quote]
Same here
I tried both android apps and they work fine…
Can you tell us what remote server the app is trying to access e.g. fwd2.mios.com or fwd1.mios.com?
fwd1mios for me.
Yesterday in the evening it didn’t work. (timezone GMT +1)
I thought it was because of the poor 3G coverage but apparently is was something @ MIOS.
Now i just checked it and it works again. ![]()
My Vera3 is on fwd1.mios.com and my Vera2 is on fwd2.mios.com. Both of them had no problems.
[quote=“garrettwp, post:6, topic:169833”]Can you tell us what remote server the app is trying to access e.g. fwd2.mios.com or fwd1.mios.com?
Still having the same problem. Trying to access fwd2.mios.com.
It magically works again for me…
[quote=“blazinace, post:10, topic:169833”][quote=“garrettwp, post:6, topic:169833”]Can you tell us what remote server the app is trying to access e.g. fwd2.mios.com or fwd1.mios.com?
Still having the same problem. Trying to access fwd2.mios.com.[/quote]
Just checked and it’s now working for me as well
Why would my vera 2 only allow me to log in when i’m on my home network but will not allow me to log in remotely. Is there some type of setting that i need to change?
Do you get any error? Can you give me more details?
When i try to access it via the following these are the error messages i get:
the homebuddy app:
error:org.rakstar.homebuddy.api
dataexception: invalid user/password
when i log into micasaverde:
I didn’t detect a unit on your home network. If you have a new unit, please connect it as shown and when the
Z-Wave light is on solid click ‘Continue’ and I’ll try to find it.
when i login using the mobile web address:
https://cp.mios.com/mobile
again this only occurs when i try to access my vera 2 account remotely. when im home on my wireless network i do not have this issue.
I also noticed that when i logged into my mios account on my home network that my vera 2 shows up under:
MiOS systems on my home network controlled by others
and in mios systems it says none.
I dont know if that helps?
