Unfortunately I have no answer for this. The code is pretty complex/complicated to understand, so looking at it doesn’t help in this case. The easiest way to answer this is by testing: start a heal and reboot mid-process. It’s preferable not to use a Vera with many devices, in case this breaks the routing table.
I have the Vera for around 6 months and everything was ok. But yesterday, the system crash, do not know why. So I decided to reboot each night. Maybe that’s not the best solution, so to have the most reliable system, what would be the best practice procedure?
The logs are probably on the server. Send me an e-mail at florin at mios dot com with your Vera serial number and the approximate date and time when Vera crashed.
