Ok great!
Will you continue developing the new dashboard And release more beta?
The new dashboard has made the use of vera much more easy.
The next thing i would like is rooms or be able to have subtiles or subgroups (Don’t now what we call them).
Then you can have all of your devices accesable without scrolling. You can reach everthing from one screen . Just Tap for exempel Livingroom and all lights(or whatever device you have there) pops up in a new Tile . Then a easy way to back to first screen(dashboard)…
Thank you Mattias for all the feedback you offered in the past weeks. Having a representation of rooms is on our list
We will continue the beta program with regular updates
Of a thing is good yo can make it when better is my motto!
One thing i think is importent when you developer the app is that you should be able to use the app Holding your phone and use with one hand. For example to get back to first screen/dashboard . If you tap anywhere outside the tile/Groupframe it Will take you back
To first screen/dashboard , not just a X to tap.
Of course your fingers cant reach the hole screen so sometimes you just have to use booth hands…
/M
So far I’m liking the interface. Would it be possible to have thermostats display the temperature like humidity sensors display the current humidity? Kind of lost this with the new interface.
One bug that still is there is that in some devices who are off and tile is grey but the light is yellow.
If i turn it on and off the light gets darkgrey as it should be.
/ m
One more possible bug - renaming scenes will disable Siri shortcuts - they need to be recreated. I think it was noted in a Google Home topic already that this causes problems for the Google Home scenes also.
Thank you for your feedback. I won’t count the one with Siri a bug considering the mechanism behind the implementation, with names. We will try in the future updates to go around this
The second one is a synchronization bug, we will look into it. Does the issue persists if you reopen the app?
Thanks. Not sure if persists as I have deleted the empty items. It should be easy to reproduce. Create a scene, add it in the app and then delete scene from Vera GUI.
