The best advice, don’t do it!
Normally if you have just one Schlage lock you can easily re-key all other non-communicating locks using z-wave Schlage manual key as a “master” key.
Things get complicated if you have two z-wave locks, you have to disassemble second lock in order to remove lock cylinder and replace pins.
I brought both locks to Lowes and the key guy reluctantly agreed to try. He also sad that Schlage advised against rekeying their communicating locks.
Anyway, he was able to re-key all my locks, but when he opened z-wave lock he found a “spare part” and he had no any idea how it was used in the lock mechanism. I brought lock home, paired it with Vera and tried to open/close via Vera. Well, didn’t work. I tried buttons on the lock, both with numbers and open/close. Didn’t work either. Manual keys worked just fine across all my locks.
I could simply bring it back, exchange to another one and try to rekey again, this time in the Home Depot, but I decided to try to fix it myself. It took me almost three hours and two pounds (I skipped my “supper”).
Findings:
The “spare” part, small unthreaded bolt with the spring happened to be the actual locking bolt. I lost the original spring and used spring from the ball pen. Ball pen spring is much stronger then original so I had to try several times cutting pieces with different length.
The entire locking mechanism seems to be very feeble. The main driving part is a small electric motor with a long spring attached to the rotor. This long spring acts as worm transmission moving plastic part that engages with the locking bolt.
Assembling lock back is not trivial, you have to place plastic part with a small pin at a certain position, inserting pin into the rotating “warm” spring. Same thing, countless errors and trials.
Finally it worked, but I would be better off doing it again.
