I’ve seen the DSC PowerPanel can communicate using an IT-100 card via RS232.
Q: What are the panels connecting RS232 to … a Vera3 (what port) or a PC?
From the DSC plug-in page:
If the IT100 is to be used with Vera, the user will have to decide the best method to interface It. This can be accomplished with any of the following options:[ul][li] Direct Connection to a USB to RS232 serial adapter thats supported by Vera such as this one.[/li]
[li] Wired Ethernet Connection via an IP to RS232 serial adapter such as WIZnet device like this one.[/li]
[li] WiFi to RS232 serial adapter such as this one. [/li][/ul]The Envisalink IP170/2DS does not need a serial adapter, and only needs to be connected via Ethernet.
There are a few ways as they have been discussed… I’m using my IT-100 connect to a wired Ethernet Connection via an IP to RS232 serial adapter such as WIZnet device. Works well…
