Redirecting debugging output
Is there a way to direct output from my scripts such that instead of going to LuaUPnP.log they go to an altnernate file?
Thanks,
Alex
You should be able to write to your own file using Lua’s regular [tt]io[/tt] package
See Lua 5.1 Reference Manual
If you write them to the same directory that [tt]LuaUPnP.log[/tt] is written to, then it will be rotated along with the other files (and will likely be kept in memory, or USB memory if you’ve configured that, instead of burning up the internal Flash memory module.
Great just what I need - thanks for that guessed :slight_smile:
