Recommendations for remote similar to GE 45600
I have only tried one remote–the Intermatic HA-09–which I got for nearly free off eBay (shipping was more than the remote). Anyway, it includes well and works pretty well for what it does. The remote has 5 ‘on’ buttons and 5 ‘off’ buttons. What’s odd is that, while the 5 ‘on’ buttons are all unique, the 5 ‘off’ buttons aren’t unique and all the off buttons cause Vera to run scene 0. So what I’ve done is use Luup and coded the ‘on’ buttons to toggle – if the device is off, turn it on…etc.
See here:
http://wiki.micasaverde.com/index.php/Intermatic_Handheld_Remotes
HA-09 do not return status to vera3 about the lamps it turn on or off thru HA-09. i.e. if I turn on a lamp from my HA-09 the vera do not have your status.
GE-45601 is a very good product ! no problem with that and easy association of vera3 scenes to your scenes buttons like no other.
I’m buying many tablets to have in many places of my home and have total control directly to vera3 thru the apps. I think this is the best way to control devices…not so cheap, but powefull.
An option for this application might be the Intermatic HomeSettings HA07C. It can be had for as little as $3.99 or a 6-pack for $18.00 on Amazon. Shipping is less than $10. So, you can get a 6-pack for less than some charge for a single unit. For some reason, this item doesn’t pop up in a regular Amazon search. These are good for placing on a table/counter and can also be wall-mounted very easily. It might seem a little bulky to some, but I’m happy with a <$10 scene controller that has more features than some >$100 switchbox mounted units.
[quote=“Piwtorak, post:2, topic:174559”]HA-09 do not return status to vera3 about the lamps it turn on or off thru HA-09. i.e. if I turn on a lamp from my HA-09 the vera do not have your status.
I’m buying many tablets to have in many places of my home and have total control directly to vera3 thru the apps. I think this is the best way to control devices…not so cheap, but powefull.[/quote]
I guess that isn’t a problem for me.
For example, when I run a scene with the HA-09 to turn on a living room lamp, the duplex outlet reports its status, confirming that the light was turned on (or off).
maybe the way I have included this controller in my vera3.
but dennis from support says for me is not possible status because the controller do not send the information to vera3.
[quote=“Piwtorak, post:5, topic:174559”]maybe the way I have included this controller in my vera3.
but dennis from support says for me is not possible status because the controller do not send the information to vera3.[/quote]
Have a look at this page:
That’s how I included the remote with my Vera 2.
You say when you turn on a lamp using HA-07 your vera updates the status of the lamp ?
if yes, I will try again using this doc.
[quote=“Piwtorak, post:7, topic:174559”]You say when you turn on a lamp using HA-07 your vera updates the status of the lamp ?
if yes, I will try again using this doc.[/quote]
Yes, with one exception. I’m using an HA-09.
But I don’t think that matters because it’s the device (not the remote) reporting the status.
Regarding the HA07, like other remotes, the “On” button for a scene is transmitted to Vera which triggers the devices. The status is updated immediately. The “Off” button action is controlled by the HA07 and isn’t transmitted to Vera, so the device status is not updated until polling occurs.
To speed things along, you could set up a scene triggered by ‘scene 0’ that does a forced poll of all devices controlled by a remote.
