Thanks for patience, as I’m just getting started with lighting aspects of my controller (VeraPlus, if it matters).
I have a existing light with one switch that I’d like to be able to control from across the room (adding a wire between the new and old switch is not an option). It looks to me that some 3 way zwave switch combos require the traveller wire of an existing 3 way circuit (GE was the one I was looking at). Any suggestions on ones that don’t require that wiring and communicate just with ZWave?
Are there any switches (master or aux) that could also indicate current status of the light?
Thank you.
