I am considering installing a MCV on my vacation rental to be able to control the door locks only. What are currently the best driven deadbolt zwave locks out there that work well with MCV?
Are you located in the US? If so, I believe the only motor-drive locks are Yale and Kwikset.
Both are supported, but there is some issues with Yale locks that are being solved in the build that is being tested right now.
There are also Baldwin locks, which are actually Kwikset, but different styles/finishes.
Just a heads up, but you can find other posts in this forum regarding to your answer. This has been asked several times.
- Garrett
