Recommendation for non-dimming, in-wall 3-way switch?
Hi, I’m looking for recommendations for a non-dimming, in-wall 3-way switch, Z-wave or Insteon. Looking around, I see a lot of dimmer switches, but not much for non-dimmer ones. This would be controlling multiple outside LED and (non-dimmable) CFL bulbs, where the total wattage < 40W.
Also, if possible, I’d rather not change out the remote 3-way switch. The bulbs are currently controlled by an old Honeywell timer switch – one that can turn lights on around sunset – and that switch only required a jumper short on the remote switch. It would be great if I could leave the remote switch alone (with or without the jumper short).
Thanks.
Most of the switches that can be in a 3-way configuration requires a specific companion (slave switch). Intermatic CA3000 (hard to come by now) and I believe the Aeon microswitches would allow you to use your own remote switches.
  • Garrett
Thanks.
I just ordered few GE 3-way switches. I will post how it goes. Over the last few months, I have not hand any issues with any of my Z-waves devices. I have few GE general switches and they perform very well.
Do you have neutral wires in both electrical boxes? Most, if not all, of the non-dimming 3-way switches require neutrals to operate, and many homes, mine included, are wired in “loop” mode where the neutral does not go to the switch box. Even though there is likely a white wire (U.S.) in the box it may not be a neutral. In loop wiring the white is the switched hot back to the light fixture, not a neutral.
Few hours ago I installed the GE 3-way switches. They work great BUT (big “but”) the instruction manual was useless. I had to get my dad (an engineer) to figure out the wiring in my house. The “recommended” GE install diagrams sometimes (at least in my situation) is incorrect. Most manufactures assume that the wiring in the house is done according to modern standards. My house is 40+ years old.
My recommendation when installing the 3-way switch set (2 switches) is to open up your current switches and check the wiring config. Then if you don’t have a neutral on both boxes, but have a “return” wire, you can use that return as a natural for the second box. It is kind of hard to explain, but we were able to install both switches without a dedicated neutral on one end by simply using the return as a neutral.
This guy demonstrate similar thing except he connects both black wires together on the other end. GE Z-Wave - 3 way switch Kit - YouTube and… he has two neutral on both sides. Do you know anyone who is an electrician or an engineer? I would get help because you need to make sure every electrical modification is done right. It can be dangerous.
EDIT: yes it comes as a set, main switch and a companion switch. But you can install them in any direction.
yes, the required neutral is a problem in my 45 year old house too. I’m guessing mine are wired in a loop also. my 45 year old switches have a black on the common of both switches and they used the same (black, white, and ground) wire for the travelers as the rest of the wiring in the house. no red, no blue, no yellow. I did use one of the existing travelers to supply hot to the other end for one of the 3-ways that was in a 4 gang - 2 gang boxes.
I’m a DIY guy, to a point…
after fiddling around with a couple of my existing 3-way circuits for an hour or so, I decided I don’t have time for this $#*& and I’d just pay an electrician do do those.
yesterday I paid an electrician $300. end result, lost an existing dimmer and replaced two switches with newer switches.
he never could get any of the GE z-wave switches to work. after a couple of hours of him experimenting I told him to abort. it then took him another hour and a half to get the old stuff working as before.
So I’m back in DIY mode. I’ve read all of the http://forum.micasaverde.com/index.php/topic,5408.240.html thread, and have some ideas on where to start. I’m sure I’ll be re-purposing some wires.
I just installed a set of the GE yesterday, and I have to say that I didn’t have any trouble with it. I had to take it apart slowly and stare at it for a while, but it works great. My house was built in the 80’s and has neutral at the master, but the catch I ran into was that my switches have line on the master and load at the slave, but GE wants both line and load at the master.
I have 14-3 between the switches, so I ran the red, white and ground into the slave, and connected the black directly to the load. If you have 14-3 between the switches (meaning a red wire is present), you shouldn’t need a separate neutral at the slave since the switch only has three connections (including ground) and 14-3 has four wires (also including ground).
@CptJack - Yours is like the diagram below. This is a bit different that the description in the previous posts.
yup
you see, the resulting installation isn’t a true 3-way switch, rather the aux unit signals the main to open/close the circuit (as Z-Waver’s diagram so clearly illustrates). I think that confuses a lot of folks when installing these devices. It really isn’t a 1:1 substitution.
i think we could create a separate forum just for 3-way switch installation questions! Personally, I’m glad to have that part of my house done and behind me already. I had one set of lights controlled by 6 switches. What a hassle.
congrats on getting it in!
Z-Wave - That’s it - but the book doesn’t have that picture, which sure would have been helpful. I just installed a 4-way today, and the benefit of doing the 3-way first was immeasurable. It’s basically the same setup with another wire nut and remote.
Bulldog - I decided the same thing today. You can’t think of it like an n-way setup any more, just one switch and networked remotes.
I just know I’m glad it all worked out. Now, if only the slaves could fire scenes…
