to turn a light off X mins after it turned on, is this correct:
HomeLights1 AND (HomeLights1; NOW > 3:00)
or should it just be:
Because the first one didnt turn the lights off after 3 mins ![]()
Both will work.
But it may be longer than 3 minutes if you do not have instant status reporting switches.
ok, thanks for that.
they are instant reporting.
will give the second one a shot
Do not forget to ARM the PLEG device.
Yes they were armed, The lights turned on, just not off.
Post a PLEG report.
I may also need for you to turn on Debug (Advanced Tab for PLEG set Debug to 1 and save)
Then collect a log:
http://YourVeraIP/cgi-bin/cmh/log.sh?Device=LuaUPnP
Demonstrate the problem.
In fact if you start capturing the Log, Then restart Vera … Then demonstrate the PLEG problem
I will also check your Day Or Night problem.
You can email me the information (My email is enabled in my profile)
Thanks Richard,
Will do this soon as i get home from work
how do i capture a log? that page just keeps flowing with log info.
Just save it, it will save from the beginning to the current point in time.
