Reading temperature from Popp Smoke Alarm
Vera 3 on UI5.
I bought the Popp smoke alarm - which supposedly can also provide the temperature (even if there is no fire).
http://www.amazon.co.uk/Z-Wave-Smoke-Detector-Temperature-Sensor/dp/B00NHYLF28
I am however unable to get it to read the temperature.
I followed instructions for the Fibaro Smoke detector - think they’d be similar, to add a virtual device to read the temperature
http://forum.micasaverde.com/index.php?topic=20325.140 (reply 141)
However - nothing comes back. I’ve verified my code “should” work by replacing the reading with a manually typed one.
If I change the device file to one provided by Vesternet for the Fibaro sensor -
http://www.vesternet.com/knowledgebase/technical/kb-46 then there is a space shown for temperature on the device - but again it never shows.
The manual here: www.planete-domotique.com/notices/P/O/POP_004308.pdf talks of Association groups - but that bit of Vera I’ve never really understood.
Has anyone had any success getting the temperature from this? It also doesn’t trip VERA if the alarm is tested.
Bump - has anyone successfully got this to work?
