Read temeperature from external device and put value to virtual device
I have a couple of rasberry pi with temperature sensors added to them.
I want to read the temperature from them from VERA and display the temperature value to a device (some kind of virtual temp device?)
How can i do this?
I can publish the values on the raspberrys in any way (XML, JSON, Http request etc)
Or i can run http commands from the raspberrys on the VERA with the values.
But i do not know how to setup the vera correct for this, can some one help me?
Thanks in advance!
Information from different parts of the forum
[quote=“capjay, post:4, topic:171662”]- create a virtual switch. Set it to off.
  • create a scene with no triggers, no schedules. Under devices, just set the virtual switch to ON
  • trigger the scene using HTTP request
  • you probably need to create another scene for turning the switch off (and call it over http as needed)[/quote]
This thread should be related to your question http://forum.micasaverde.com/index.php/topic,2013.0.html
This may also be relevant: http://forum.micasaverde.com/index.php?topic=14949.0
Thanks alot! :slight_smile:
if the temperature is somewhat via web avaiable … its easy to do … i have the temperature of my raspberryPI show on the vera this way :stuck_out_tongue:
