Reactor log
When a reactor sensor is activated, we have a log entry in the form of: Luup_log:device:xxx: Reactor: “sensor name” (#xxx) now “tripped”. This is a very quick and easy way to check if the sensor is behaving as expected without going in the details of the whole sensor evaluation log entry. However, as per you recommendation, the use of groups to carry several action within a sensor does not provide this type of simple log enty. All we have are the Reactor sensor evaluation and the actions following it. The information is there but not as easy to find.
Is there any way to have similar log enty for a group performing an action similar to the sensor one?
Ideally, since the main sensor group is rarely used, generating a log entry, when the “is true”, “is false” activities associated to a group is performed, would be a nice addition.
For your consideration
Improved logging for activities is part of 3.6 (upcoming).
Many thanks for that
Hi all,
I was checking my luaupnp log and I come across this log:
This is old:
[386 / r364s4] Gate Reactor Sensor 1
This sensor was delated few months ago but Vera is still looking for this device?
Can anyone recommend fix for this?
