Hi
Really grateful for your help with thisā¦there was a time 20 years ago when I could knock out some arps, net stops and greps. But the passage of time has taken its toll
I havenāt flushed a DNS cache; I assume that this would need to be in the Edge and I donāt know how to get into it to do that.
I can nslookup all the names that youāve listed below and get the same IP addresses back. More simplistically, if I ping those names, I get the same IP addresses back in the pings which are all successful. (This all being from my laptop which gets a DHCP address from the router and so then uses its Sky DNS servers).
Iāve just changed the DNS server in the Edge from 8.8.8.8 to the first of the Sky ones. When I click on the Troubleshoot Network button in the Edge interface, I get the following:
=== IP Configuration ===
br-lan Link encap:Ethernet HWaddr E0:60:66:00:B5:0B
inet addr:192.168.0.50 Bcast:192.168.0.255 Mask:255.255.255.0
eth0 Link encap:Ethernet HWaddr E0:60:66:00:B5:0B
eth0.1 Link encap:Ethernet HWaddr E0:60:66:00:B5:0B
inet addr:127.0.0.1 Mask:255.0.0.0
ra0 Link encap:Ethernet HWaddr E0:60:67:00:B5:0C
External IP: 94.194.37.152
=== Testing Gateway: 192.168.0.1 ===
ā¦
GATEWAY:OK
=== Testing DnsServer: 8.8.8.8 ===
ā¦
DNSSERVER1:OK
=== Testing DnsServer: 90.207.238.97 ===
ā¦
DNSSERVER2:OK
=== Testing External Servers ===
ā¦
GOOGLE.COM:OK
ā¦
STA server: network errors detected
ā¦
EVT server: OK
TS server tunnel connection: OK
ā¦
FWD server: OK
FWD server tunnel connection: OK
=== SSH_TUNNELS: ===
Found 12 ssh sessions running
Remote Control Tunnels are running
== DONE ==
When I had 8.8.8.8 in the DNS setting, the DNS checks failed.
That output above now looks quite clean apart from the STA server, I donāt know what implication that has.
I had a moment of hope when I saw that output but now again, when I login to the Vera server, it still lists my controller but shows it as offline.
Iām intrigued by the 192.168.0.50 address. I have it fixed as 192.168.0.92. If I look at my laptopās arp cache, it shows both 50 and 92 with the same mac address (which is the Edge one)
Iāve also done two other tests⦠I changed the Edge connection from Ethernet to wifi and connected it to my phone hotspot. It then connected and worked as Iād expect it to.
I then took the Edge to a friendās house and plugged it in to his router supplied by EE, here again all worked as Iād hoped, I could login to the Vera servers, the controller was listed and shown as Online and I could click through to access it. I did no configuration, eg port forwarding on the EE router.
Santa did indeed shop at Vesternet. They responded quickly but havenāt come up with anything that has resolved the issue. They said:
We haven?t heard of these problems with Sky however it seems very similar to what happens with BT http://www.vesternet.com/knowledgebase/technical/kb-73
Odds are Sky is now doing the same as BT and blocks third party DNS servers to prevent bypassing its ?Sky Broadband Shield?. What happens if you manually set ur PC DNS server to something as 8.8.8.8?
You can also try to disable the Shield and see if it makes a difference Sky Help | Sky.com
The problem is that Vera will use it?s on DNS servers instead of Sky DNS servers and some ISPs are now blocking this as a ?secure measure? meaning the problem is not on you accessing Vera but Vera being unable to reply back.
Basically you?ll need your Sky hub to give completely unrestricted access to Edge ? maybe it has a DMZ setting on the hub you can use?
Stop Press, just run Network Troubleshoot option again, STA server is happy, other ones are not.
ā¦
GATEWAY:OK
ā¦
DNSSERVER1:OK
ā¦
DNSSERVER2:OK
ā¦
GOOGLE.COM:OK
ā¦
STA server: OK
ā¦
EVT server: network errors detected
TS server tunnel connection: FAILED
ā¦
FWD server: network errors detected
Found 13 ssh sessions running
== DONE ==
I could remove the controller from my account and reset to factory defaults to start again. Would need to re-add all my sensors etc but would be worth it if it worked. But, given that Iāve managed to get through OK using EE and vodafone as above, Iām not sure that this would help.
Not sure if any of the above leads you to any conclusions.
Iām probably going to seek out another friend with a different broadband supplier again, then email the story to Sky Support. I donāt have high hopes of a positive response from them though, anything non-standard doesnāt usually get much of a helpful response.
cheers
