Re-install DataMine
I have a Veralite and installed dataMine over a year ago for a temperature measuring project and it worked well. Vera has controlled my central heating perfectly over the year but now I want to pick up the sensor project I find an error dataMine #21[21] : Startup Lua Failed. I thought I would just re-install but I don’t see dataMine in the marketplace any more. How can I re-install?
If you do a search in the market for Datamine I think you’ll find it’s still there, even if browsing doesn’t find it. I installed it two days ago and it was there then. :slight_smile:
Well I’m puzzled, A search returns “no records” and alphabetical sorting goes from “CurrentCost” to “Day and Night”. Is this because it is currently installed ( but not working)?
Sent from my iPad using Tapatalk HD
datMine Plugin
OMG! It’s a miracle!
OK found it from web rather than via Vera. Thanks.
