Ramp lights in scene
Hi this might be an easy question to answer, but I cant seam to work it out. I would like to set a scene where the lights ramp up to set level over say 5 seconds and if they are on the leave at that level.
Thanks in advance
Rob
Use the wakeupramp plugin, create a scene which runs it with some luup code that checks the status of the light and doesn’t run the scene if it’s on.
Cheers will have a look.
