Hi all
attached is the initial release of a new Rain8Net plugin: -
[url=http://www.wgldesigns.com/rain8pc.html]http://www.wgldesigns.com/rain8pc.html[/url]
[size=14pt]Updated plugin[/size]
[ol][li]Upload attached files[/li]
[li]Create device[/li]
[li]Restart LUUP engine[/li]
[li]Add each module to list comma delimited (ModId)[/li]
[li]If zone has a master valve associated this can be added in format “0101” Hex address of master valve (PumpNumber)[/li][/ol]
What it should do is create all valves and inputs associated with module addresses in ModId
Limitations
UI5 only - cause I’m lazy
Not tested
Auto create of counter functionality as I don’t have one set up as yet.
Should work on both serial and ip networks. I am using ip so not sure about serial.
To be implemented
Max valves allowed.
ProgramA & ProgramB with Timers for irrigation cycle. Completed
Skip functionality. Not required
Use “state engine” for startup.
Implement “Global Off” and “Module Off” in UI Completed
There is already a plugin available but I have had this one in progress (now completely re-written) before I found out about the existing one.
Thanks to all on this forum for their help specially guessed who’s IORelay plugin “state machine” looks superficially like mine :). It took me awhile to understand how that fitted together. @guessed Hopefully you don’t mind my use of the code.
