Radio Thermostat 3M-50 Wifi support
Hi, I just got a Vera plus (with UI7) and I have 3 radiowifi thermostats.
In reply to another persons question…yes you can use these thermostats with the Z-wave, and the wifi module installed at the same time. They will work with both simultaneously.
My question is around the plugin. I have the “Radio Thermostat Wi-Fi Plugin” installed and configured with the IP of one of my thermostats. It sees the thermostat and I’ve even validated that I can click “On” in the gui under the fan section and the fan will turn on (fmode gets set to 2 as confirmed via curl separately). However, the current temperature is not displayed in the web interface and in the android app I get no information at all. Is there a way to easily modify the plugin to affect the gui for both the web and the android app? I’d like to do things to improve the WAF like labeling the two set points (currently you don’t know which is heat and which is cool) and adding a few more status items, like displaying the variable for ModeState and CurrentTemperature? Also for this to be useful I need it to work on the Android app. I can control the thermostats via the generic z-wave thermostat plugin via android, but all of my thermostats don’t have z-wave. Is there a way to “copy” some of the elements of the generic z-wave thermostat UI and use them on this apps ui?
It seems like a bit of UI work could make this plugin VERY functional. Both the generic z-wave thermostat app and this app both have some good UI benefits, I’m hoping there is an easy way to get the benefits of both combined into one.
