Quickie - Steps to Turn On/off (or something else) when a sensor is tripped
To do something when a Door Opens
  1. Create a Scene
  2. Go to Events to create an Event
    a. Select your sensor
    b. For the Dropdown “what type of event is the trigger” , select “ A sensor is tripped”
    c. Select Tripped Dropdown to “Yes”
    d. Optional you can select your user name to get email if you check notify.
    e. Next Go to Commands Tab
  3. Go to commands to create a command
    a. Select the device and choose what command (On/Off)
To do something when a Door Closes
Follow the previous steps, except in step 2.C select Tripped Down to “No”
BTW Folks – This is NOT user friendly the first time (its bit confusing), then once you figure out, you get the hang of it :slight_smile:
helpful. thanks!
mcv should really pay some folk to have some nice documentation for basic stuff like this. ::slight_smile:
BTW you could also refer the post here to do this based on a condition :slight_smile:
http://forum.micasaverde.com/index.php?topic=7915.msg50717#msg50717
