I struggled through and got a scene that turns on 3 different lights in the evening, but I can’t figure out what to add to get them to turn off. I used the delay of 4 hours (come on at 8pm then 4 hour delay, so they will go off at midnight), but I don’t know how to trigger them going off. What do I add?
thanks!
Sounds like you need a similar scene to turn them off. :
Do you mean the 4 hour delay isn’t working? If you trigger the scene and it turns the 3 lights on, in 4 hours it should turn them off. However, you can’t restart LUUP or reboot Vera in the meantime. If you do, the 4 hour timer will never happen.
If you want a delay to survive a LUUP restart or power cycle, you can use the Countdown Timer instead. That is designed to be restart-safe.
