hi everyone!
I’m setting up a manual scene that would turn off some lights and set the system on AWAY. I see no easy option to set the system “Away” so I’m thinking of a Luup command, what would be the code to set the system as “Away”?
Thanks!!!
hi everyone!
Thanks!!!
If you are running UI7 you can try the House Modes plugin → MiOS Apps.
Its easier then writing Luup code if you’re unfamiliar with it.
See this thread for the luup call to set the House Mode.
Awesome! Thanks guys!
