I purchased a Vera2 specifically to allow remote administration of my DSC PC1832 alarm system through the IT-100 serial interface. So far, the only information available for configuring Vera2 to work with the 1832 has been in the forums, which I have found to be extremely confusing. The attempts that I have made so far have resulted in nothing that works. I tried calling MiCasa Verde a couple of times for technical support and was sent to voice mail.
If anyone has had success in a similar integration, I have a couple of questions to which I have not been able to find answers:
A Wiki hosted at DSC Alarm Panel makes an attempt at walking through configuration but it is preceded by a comment that “This plug-in will probably not work with the “UI3” (versions 1.1.x) of Vera’s firmware”. When I check the firmware level of my user interface, it says that I am running the latest version: 1.1.1245. Does this mean that I can disregard any further configuration advice because it probably wont work?
If I actually can configure the Vera2 to interface with my 1832, is there a definitive configuration guide or HOWTO available? All that I have seen so far are bits and pieces of discussions that discuss firmware quirks, patches, and work-arounds.
I would greatly appreciate any help that those of you in similar situations can provide.
Thanks - M
