guessed,
I have a couple of simple brultech questions that you may be able to help me with. I’m going for a low-budget monitoring of a few circuits and so a single ECM-1240 should do me fine. Also, I will pull an ethernet cable for it for a wired connection to my laptop. My laptop is connected to the home network (DSL modem) via wi-fi and I’m wondering if having a wired connection to the laptop’s ethernet port would cause any problems. Wouldn’t the 1240 just show up as another networked device?
Secondly, I can’t really tell from the screen shots at brultech exactly what info I could get using their dashboard software. I would just need monthly kwh for a few appliances and I assume data this basic should be available on the dashboard. Is that a good assumption?
I’ve sent emails to the sales brultech but they are apparently very slow to respond. Must be very busy.
Thanks much for any help
Eric
