this is probably a noob question but i can’t figure this out.
this is my first use of it and it seems like the thing that i want to use a lot but just need to get the basics working.
So, i have a front door switch and a power socket switch. i want the power socket (lamp) to turn on when the front door opens. but i only want this to happen when i come home. So leaving in the morning i don’t want the lamp to turn on when i go out.
At the moment it turns the lamp on every time the door switch triggers…
the front door sensor is my trigger input. i have a schedule set to weekdays, at a certain time of day and set for 14:00.(anything after that i will be coming home and not going out). i also have stop type, day of week, certain time of day 22:00.
i have condition door sensor triggered, action turn switch on.
so, i thought that the input trigger and the schedule both had to be true for the condition to be met. Or do i need to make my condition statement door sensor triggered AND schedule. I tried doing that but i can’t get it add the schedule after i do the Logical operator.
BTW i haven’t purchased a license yet so not sure if there is limited functionality until you do.
cheers
