Now… can someone explain what “id=” is? I can’t find that documented…
In the first request it obvious that id=lu_variableget means I am getting a variable.
In the second request this is a request lifted from the smart phone plugin.
But what really does “id=” mean? What are acceptable values?
when I run the second example it works fine, but the output from the call is formatted like the result page is on a smart phone. What needs to be done to this so the result from changing the setpoint is simply an “OK” or some clean ascii text return. I just need to know if it worked or not. (result will be stuffed into a string for evaluation) I figure it must be some other form if id= but again, I have no clue what can/should go here.
Thank you for those bits of info… its amazing what is out there if you just know where it is. Most times I can search around for awhile and stumble on it, this one had been bugging me.
When I run this, it works, but instead of OK i get back an incrementing number each time its called… 8 14 16 23. I assume this is the task/job #. If for some reason it does not work properly do I get some error code/message instead?
At least with setting variables I assume that anything other than OK means it didn’t work.
I tacked on the Cool suffix because of this documentation:
Service
* urn:upnp-org:serviceId:HVAC_UserOperatingMode1
o For action SetModeTarget
* urn:upnp-org:serviceId:TemperatureSetpoint1_Heat
o For action NewCurrentSetpointHeat
* urn:upnp-org:serviceId:TemperatureSetpoint1_Cool
o For action NewCurrentSetpointCool
* urn:upnp-org:serviceId:HVAC_FanOperatingMode1
I removed the suffixes on the page, did a little formating, added 2 examples, and got rid of the dummy Latin.
BTW, the captcha for creating a wiki user is broken for Firefox 3.6. The captcha is also broken in chrome for external links in a wiki edit. I just removed http:// to get around that.
