I’m still adding devices to my system and in-between adding them I run a heal because things start to get weird. Looking at the blue bar at the top of my screen (UI7) should I pay any attention to whats displayed there. The reason I ask is it often says something like “0 successful routes out of 0” which would suggest no routes were found to be good. Or is this just worthless info…?
It means that Vera isn’t aware of a route through intermediate node to the device. But, it doesn’t mean that Vera can’t talk to the device. It’s not completely worthless, but it probably won’t be a problem for you.
Add your devices, heal the network, and then if something doesn’t work, the 0 routes may be significant in troubleshooting the issue. Usually the fix would be to add intermediate nodes to provide a route to the device that doesn’t work.
