This is not really a how to question…I’d like to know if it can be done with an Veraedge before ordering the parts(UI7)
Can I create a scene that would:
Every 2 second turn on a WO15Z-1 wall outlet…across 25 outlets. Basically outlet #1 turns on, outlet #2 turns on 2 seconds later, outlet #3 turns on 2 seconds later …etc to outlet 30.
Using an Cooper RF9540 dimmer, can I create a scene that will increase the brightness of the lights? For example…lets say across 5 seconds…the brightness goes from 10% to 100%…then maybe 100% back down to off?
Again…would just like to know if it’s possible using the standard UI built into Veraedge before I shell out a grand in parts
Thanks!!!
Modify message
