[quote=“integlikewhoa”][quote=“DaveH28, post:8, topic:188757”][quote=“integlikewhoa”]The power pack is not a vera item. It’s not internal nor does the vera know its even connected. Its just an inline battery pack thats plugged into the same port as the wall outlet. As far as vera knows its plugged into the wall.
Yes it will pair if you move it closer to the device. Problem is you might have an issue after you move the controller far away again back to where it sits.
I would try it if not your best option would be to install 7.09 or older firmware.
Which firmware are u using right now?
7.11 just came out 2 days ago and has many issues.[/quote]
Yes you are 100% correct about the battery pack. The Vera just has power and doesn’t know anything else. I liked that the lite had this feature built in. They should’ve kept it for the edge but I guess it wasn’t in the master plan.
Anyway, I just upgraded the firmware yesterday at the recommendation of MCV support, who was working with me to resolve some issues I was having. So I’ve got the new version, which I didn’t realize had issues until now… Lol
By the way I don’t think I thanked you for your replies… I appreciate the help![/quote]
Newest is definitely not better with MCV. You need to read what fixes are out and what new problems it creates. See if the fixes are worth the new hassles. I would suggest you got back to 7.09 or older which is before the z-wave chip got updated and the problem your having now started.[/quote]
I understand what you’re saying but in all fairness, the issue I’m having with my ca3750 is not new to this firmware upgrade. I’ve been having it for about a week but I couldn’t even access my Vera on my computer until support helped me get in. Now that I can get in I was going to try and re-do the ca3750.
They resolved the issue I was having with the ad2usb and with my thermostats. But today my door locks stopped responding.
It’s always something. I probably should’ve just bought a second Vera lite instead of the edge but I figured it would be faster, more responsive, and easier to customize. So far it’s none of the three. I really didn’t have many problems with the lite. (Which goes along with your newer is not necessarily better assessment)
