Can you help me with this mistake please ?
[code]
– Action 1 : OK => t = 0
local t = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “Tripped”, 4)
luup.log(t)
– Action 2 : KO => t2 = nil
local t2 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”, “BatteryLevel”, 4)
luup.log(t2)[/code]
I can retrieve “Tripped” but not “BatteryLevel”.
I don’t understand because the BatteryLevel is OK in Advanced Settings (see attachment).
I’m using Vera Lite UI5 and HSM02 Motion Sensor.
Many Thanks
I found the solution by chance looking at the logs.
I have to change the ServiceId.
local t2 = luup.variable_get("urn:micasaverde-com:serviceId:HaDevice1", "BatteryLevel", 4 )
luup.log(t2)
How can I find this information with UI5?
Most of the services, variables and actions used by MiOS can be found here: http://wiki.micasaverde.com/index.php/Luup_UPNP_Files#HaDevice
For others you must look in the Luup files: in the device files (D_…xml) to see the service IDs and in the service files (S_…xml) to see the variables and actions for a service.
Also going here:
http://:3480/data_request?id=lu_invoke
Can give you an idea of what type of parameters can be used with each device. It will not show all the variables, just ones that can take a request.
Perfect
I have now finished setting up my new vera thanks to your advice.
Thank you very much.
