Question about accessing Vera data
Hi All,
I want to develop an Android app that can get sensor data. Sensors connect to Vera through Z-Wave. Is there a way that I can access data stored in Vera through Java? Thank you.
Absolutely. You are essentially writing a very specialized control point app that can only show you one value from Vera.
See here for the general idea. It’s quite involved. You may be able to take some shortcuts if you can promise that your Android app is always on your LAN, and that Vera has a static IP address in your LAN.
