Qubino Temp Sensor on Dimming or Relay modules
Hi
Looking at the Qubino Modules with the additional Temp sensor.
My question is, would the temp sensor in the Qubino modules be more or less reliable/accurate than the Fibaro 3 in 1 sensors?
Where would you mount the temp sensor, just behind a switch? not sure where else i would have it to keep it hidden but to report a meaningful accurate temp.
In each room, there could be a ?30 saving to go with the Qubino+ temp sensor rather than the Fibaro modules + Fibaro 3 in 1 sensors
N
