I am using a Qubino Flush On/Off Thermostat to monitor the temperature of a pipe to verify the heating system works in freezing conditions. The thermostat installed in the UI7 network fine and it?s reporting temperature. I want to set it to send a notification when the temperature gets too low. The notifications drop down window only show 2 options for notifications ?Thermostat mode changes? and ?Ambient temperature goes above?. How do get the option of having a notification for ?Ambient temperature goes below??
You can make a scene based on the temperature readings from this device.
That worked perfectly; Thanks
