The Qubino Flush dimmer is an interesting device, not least because it’s a trailing edge dimmer
[b]Big range of bulb types[/b]
The first (MOSFET switching) dimming module in the world which also supports control of low voltage halogen bulb with electronic transformer and dimmable compact fluorescent light. Qubino Flush dimmer supports also the classical incandescent lights, halogen lamps operated by 230 VAC (High Voltage Halogen), dimmable fluorescent lights and dimmable LED lights.
A compatibility guide provided by my favourite supplier claims that the binary inputs are not working together with firmware 1.5.622. The statement is ambigous so it can be interpreted in 2 ways though… I’ve been looking around on the Internet to get this confirmed but I haven’t been able to do so.
Did someone actually try using the binary inputs with firmware 1.5.622 ?? Please drop a line and tell me about your experience. Thanks.
Trailing-edge dimmers are more sophisticated than leading-edge dimmers, and usually use a MOSFET (Metal Oxide Semiconductor Field Effect Transistor) or IGBT (Insulated Gate Bipolar Transistor) switch rather than a TRIAC and coil. This benefits the user with smooth, silent dimming control, absent of any buzzing noise.
A trailing-edge dimmer has a lower minimum load (often 10W) than leading-edge dimmers, making it a better choice for dimming modestly sized low-powered lighting circuits.
Particularly beneficial for incandescent and halogen bulbs is the ?soft start? feature in trailing-edge dimmers, which prevents filament bulbs from dying or exploding of thermal shock when first switched on.
Hi, i’ve got a Qubino Dimmer set up on UI5 (the 1.5.622 version of the firmware) and i don’t have the input problems you described. See the attached image to this post, this is what i see when i activate both inputs. I do remember i had some trouble getting the UI to refresh the status of those inputs, but after a browser cache reload they display and refresh correctly.
I use I2 and I3 inputs (the ones that have binary sensor endpoints attached to them) as triggers for scenes that i activate via push buttons. Makes it easy to have blinds close and lights dim at the same time without having to grab my phone or PC.
Can you share the link where you said they described them as not working?
I’d like to see if they found any issues with them, but so far i am pleased with the module myself. Similar price to Fibaro Dimmer, but with more functionality as i see it.
[quote=“Nublet, post:2, topic:183587”]Hi, i’ve got a Qubino Dimmer set up on UI5 (the 1.5.622 version of the firmware) and i don’t have the input problems you described. See the attached image to this post, this is what i see when i activate both inputs. I do remember i had some trouble getting the UI to refresh the status of those inputs, but after a browser cache reload they display and refresh correctly.
I’d like to see if they found any issues with them, but so far i am pleased with the module myself. Similar price to Fibaro Dimmer, but with more functionality as i see it.[/quote]
That’s great news. Thank You very much. Here is the link but the document is in swedish.
Vera: I senaste officiella firmware (1.5.622): Fungerar att dimmra och energim?tning visas korrekt. Ansluten temperatursensor visas ej. Bin?r ing?ng fungerar ej.
I Beta 1.5.672 eller senare: Allt utom temperatursensorn fungerar utan problem.
Same text translated by Google:
Vera: In the latest official firmware (1.5.622): Works to dimming and energy measurement properly displayed. Connected temperature sensor is not shown. Binary input is not working
In Beta 1.5.672 or later: Everything except the temperature sensor works without problems
[quote=“farang, post:3, topic:183587”][quote=“Nublet, post:2, topic:183587”]Hi, i’ve got a Qubino Dimmer set up on UI5 (the 1.5.622 version of the firmware) and i don’t have the input problems you described. See the attached image to this post, this is what i see when i activate both inputs. I do remember i had some trouble getting the UI to refresh the status of those inputs, but after a browser cache reload they display and refresh correctly.
[/quote]
Thanks for that link. It makes looking for new z-wave devices much easier :)
The temperature sensor indeed doesn't display on the widget, the temperature is instead displayed on advanced tab of the settings under the field CurrentTemperature. I then use it via luup code where i need it myself. Got one of their single switches i plugged the sensor into and used it as a sprinkler system monitor. Just needed to extend the stock sensor cable length so i could put the sensor outside, the rest was fairly simple.
