I would like some information about how to set up the Qees MyKey in vera3.
How to set up the groups and the sceens associations and so on.
I have partly made it work but had a problem with the Fibaro 2x1,5 relay, where I only could make one of the lights working (the wrong one afcause).
I also want i on a spesefic butten. Then I tried sceens. Can you turn sceens on/off on the same button ?
Maybe Mcv or Qees could make something in writing about setup and possibillities ?
Maybe vera needs an update ?
The remote sems to work perfectly.
Regards
After long times try and error I finally made it. It works fine.
But a bit of information on how to use it in vera would have been a great help.
Regards
By any chance are you in North America? I have been waiting for them to cross the pond.
Did you get each key to activate a different scene?
I have one of the older Qees rings, and I can only get it to directly activate a z-wave device (Using ‘Device options’), not a scene.
Alex
To Alex
Yes, it works with scenes, but I have not yet found out if it can activate and deactivate a scene from the same button.
To Paul
No I am on the other side of the pond, but here is a link were you can order, they are quite trustworty: http://www.etotal.eu/
Regards
CES
Thanks for the link, but it appears to me that they are only selling the EU version.
I am pretty sure they sell the us version as well.
Send them a mail
Please, can you explain how you did ?
