puzzle
Hi there,
I have made a PLEG function to arm and disarm alarms and try to get an alarm when a sensor is tripped when i arm the alarm. It works for the most, but my problem is that it worked in a loop. If I put a warn in it to warn me on an open door when arming it also disables the alarm when a real alarm occurs.
To prevent that I put in a virtual switch that will go on 10 seconds after the alarm is armed. My problem now is that the warn needs to be aware that it only warns when the new virtual switch (AlarmSet) is NOT on. I think I got the syntax wrong.
Also my remote arm won’t work anymore.
Any help is welcome.
AlarmSystemScheduler
Device ID: 802013-10-26 13:42:45.278 PLC Version: 5.1
Triggers
Name Description Last Trigger State
Door1Motion Door sensor 1 armed is tripped 2013-10-26 13:05:58.655 false
Door2Motion Door sensor 2 armed is tripped 2013-10-12 18:29:54.885 false
SensorFrontMotion Motion 1 armed is tripped 2013-10-26 03:57:11.050 false
RemoteArm Remote: scene number 1 is activated 2013-10-26 12:04:25.765 false
RemoteBypass Remote: scene number 2 is activated 2013-10-26 12:04:31.025 false
SensorBackMotion1 Motion sensor 2 armed is tripped 2013-10-26 13:37:11.655 false
Schedules
Name Type Time Days Random On Delay Off After Type Off Time Off Days Random Off Delay State Last Schedule
RequestArm Weekly 00:30:00 1,2,3,4,5,6,7 None None None false 2013-10-26 00:30:00.805
RequestDisarm Weekly 06:00:00 1,2,3,4,5,6,7 None None None false 2013-10-26 06:00:00.100
Device Properties
Name Device Name Device Variable Last Change Value
AlarmOn AlarmOn/Off Status 2013-10-26 13:37:33.750 0
SetAlarm AlarmSet Status 2013-10-26 13:37:33.921 0
Conditions
Name Expression Last True State
Alarm_On AlarmOn == 1 2013-10-26 13:36:24.909 false
Alarm_Off AlarmOn == 0 2013-10-26 13:37:33.753 true
RemoteArm RemoteArm == 1 2013-10-26 12:04:25.765 false
RemoteBypass RemoteBypass == 1 2013-10-26 12:04:31.025 false
Door1 Door1Motion == 1 and SetAlarm == 1 2013-10-26 12:59:44.610 false
Door2 Door2Motion == 1 and SetAlarm == 1 2013-10-12 18:29:54.891 false
SensorFront SensorFrontMotion == 1 2013-10-26 03:57:11.057 false
SensorBack SensorBackMotion1 == 1 2013-10-26 13:37:11.680 false
Autoarm RequestArm and (not Door1Motion) and (not Door2Motion) and (Door1Motion;RequestArm) AND (Door2Motion;RequestArm) 2013-10-26 00:30:00.818 false
Warn1 Alarm_On == 1 and Door1Motion and (not SetAlarm)and(Alarm_On;Door1Motion)and (SetAlarm;Door1Motion) 2013-10-26 11:29:33.429 false
Warn2 Alarm_On == 1 and Door2Motion and (not SetAlarm)and(Alarm_On;Door2Motion)and (SetAlarm;Door2Motion) 2013-10-12 18:29:54.905 false
AutoDisarm RequestDisarm 2013-10-26 06:00:00.118 false
Alarm_Set AlarmOn == 1 2013-10-26 13:36:24.936 false
Alarm_Set_Off AlarmOn == 0 2013-10-26 13:37:33.797 true
Actions
Actions for Condition: Alarm_On
Immediate
Device Action Arguments
Door sensor 1 SetArmed newArmedValue=1
Door sensor 2 SetArmed newArmedValue=1
Motion 1 SetArmed newArmedValue=1
Motion sensor 2 SetArmed newArmedValue=1
Actions for Condition: Alarm_Off
Immediate
Door sensor 1 SetArmed newArmedValue=0
Door sensor 2 SetArmed newArmedValue=0
Motion 1 SetArmed newArmedValue=0
Motion sensor 2 SetArmed newArmedValue=0
Actions for Condition: RemoteArm
Immediate
AlarmOn/Off SetTarget newTargetValue=1
Actions for Condition: RemoteBypass
Immediate
AlarmOn/Off SetTarget newTargetValue=0
Actions for Condition: Door1
Immediate
Keuken LED SetTarget newTargetValue=1
Schijnwerper achter SetTarget newTargetValue=1
Schijnwerper voor SetTarget newTargetValue=1
Siren And Strobe SetTarget newTargetValue=1
Strijklicht aanbouw SetLoadLevelTarget newLoadlevelTarget=100
Tafellicht achter SetLoadLevelTarget newLoadlevelTarget=100
Vijverlicht SetLoadLevelTarget newLoadlevelTarget=100
Licht voorkant huis SetTarget newTargetValue=1
Aanbouw SetLoadLevelTarget newLoadlevelTarget=100
Boekenkast licht SetLoadLevelTarget newLoadlevelTarget=100
Servieskast licht SetLoadLevelTarget newLoadlevelTarget=100
Eetkamer SetLoadLevelTarget newLoadlevelTarget=100
Gang SetTarget newTargetValue=1
Hal SetLoadLevelTarget newLoadlevelTarget=100
Kamer hoofdlicht SetTarget newTargetValue=1
Laetitia SetLoadLevelTarget newLoadlevelTarget=100
Lamp tiffany SetLoadLevelTarget newLoadlevelTarget=100
Schilderij spot SetLoadLevelTarget newLoadlevelTarget=100
Keuken SetLoadLevelTarget newLoadlevelTarget=100
Keukenkast licht SetLoadLevelTarget newLoadlevelTarget=100
Schuur licht SetTarget newTargetValue=1
Actions for Condition: Door2
Immediate
Actions for Condition: SensorFront
Immediate
Delay 10:00
Schijnwerper voor SetTarget newTargetValue=0
Actions for Condition: SensorBack
Immediate
Delay 10:00
Schijnwerper achter SetTarget newTargetValue=0
Actions for Condition: Autoarm
Immediate
Actions for Condition: Warn1
Immediate
Siren And Strobe SetTarget newTargetValue=0
Strijklicht aanbouw SetLoadLevelTarget newLoadlevelTarget=0
Tafellicht achter SetLoadLevelTarget newLoadlevelTarget=0
Vijverlicht SetLoadLevelTarget newLoadlevelTarget=0
Licht voorkant huis SetTarget newTargetValue=0
Aanbouw SetLoadLevelTarget newLoadlevelTarget=30
Boekenkast licht SetLoadLevelTarget newLoadlevelTarget=30
Servieskast licht SetLoadLevelTarget newLoadlevelTarget=30
Eetkamer SetLoadLevelTarget newLoadlevelTarget=40
Gang SetTarget newTargetValue=0
Hal SetLoadLevelTarget newLoadlevelTarget=40
Kamer hoofdlicht SetTarget newTargetValue=0
Laetitia SetLoadLevelTarget newLoadlevelTarget=30
Lamp tiffany SetLoadLevelTarget newLoadlevelTarget=30
Schilderij spot SetLoadLevelTarget newLoadlevelTarget=30
Keuken SetLoadLevelTarget newLoadlevelTarget=0
Keukenkast licht SetLoadLevelTarget newLoadlevelTarget=0
Schuur licht SetTarget newTargetValue=0
Actions for Condition: Warn2
Immediate
Actions for Condition: AutoDisarm
Immediate
Actions for Condition: Alarm_Set
Delay 10
AlarmSet SetTarget newTargetValue=1
Actions for Condition: Alarm_Set_Off
Immediate
AlarmSet SetTarget newTargetValue=0
Notifications
Name Description Users Last Sent
Door 1 Open AlarmSystemScheduler has satisfied condition: Warn1 Patim 2013-10-26 11:29:33.429
Door 2 Open AlarmSystemScheduler has satisfied condition: Warn2 Patim 2013-10-12 18:29:54.905
Nobody?
I guess that it is the following syntax:
Alarm_On == 1 and Door1Motion and (not SetAlarm) and (Alarm_On;Door1Motion) and (SetAlarm;Door1Motion)
It seems that only that part is not working.
Correct me if I’m wrong.
You need to have patients. You only asked the question a few hours ago. Asking if anyone knows only after posting an hour and half of the original post is considered rude and will most likely make the sensor members of this forum ignore your post. Also understand that many members of this forum are from all over the world and have vastly different schedules than you do.
  • Garrett
Sorry,
It wasn’t my intention to be rude. It’s just I am so into this system that I didn’t notice time.
My apologies.
