Ok, it says Master.stable now, but still no pushover in the dropdown list. Have done a reload.
Did you hard refresh the browser? The āmaster.stableā thing is odd, it should say Github.stable. The version reported in the plugin UI (e.g. Tools tab) should be 20295.
Sorry, itās of course Github.stable. But the version is wrong itās 20262. I tried it again without success. I will check the logging later.
Ok, itās solved. Iāve updated my openluup docker and now it updated to the new version and I have pushover in the dropdown list. Thnx!
Hi rigpapa, is the ability to use Pushover something that I should be able to do in the current version on the standard Vera UI? It looks like I have v3.8-20262 installed but I canāt see pushover in the dropdown list for the Notify activity.
EDIT: I just noticed that you said version 20295 should be the version, but it looks like 20262 is the last stable release. Should it work on that version or do I need to upgrade it somehow? If I need to upgrade it do you have any advice on how? I haventā customised by Vera at all other than a couple of plugins like Reactor and am just using the normal interface.
EDIT2: Donāt worry, I found the information you posted in another thread. I thought Iād searched but searching again came up with what I needed. For anyone else that reads this thread and not the other I upgraded to the stable using the instructions here:
Thanks for such an awesome plugin. With all the info on the forum Iāve managed to work out almost everything I need without having to ask any questions!
Hi, the following Error 404 appears in my logs every time I send a Pushover notification. The message gets through, just wondered if anyone could give me a clue how to remove the error as my Vera is struggling a bit and every little bit of fine tuning helps:-
6 10/06/21 14:56:00.457 Device_Variable::m_szValue_set device: 58 service: urn:upnp-org:serviceId:IOSPush1 variable: TimeSend was: 1633528511 now: 1633528560 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x6d24f520>
06 10/06/21 14:56:00.457 Device_Variable::m_szValue_set device: 58 service: urn:upnp-org:serviceId:IOSPush1 variable: PushOverCount was: 147879 now: 147880 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x6d24f520>
06 10/06/21 14:56:00.458 Device_Variable::m_szValue_set device: 58 service: urn:upnp-org:serviceId:IOSPush1 variable: LastError was: Ok - 14:55 - (PushOver) now: Ok - 14:56 - (PushOver) #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x6d24f520>
01 10/06/21 14:56:00.525 FileUtils::ReadURL 0/resp:404 user: pass: size 316 http://vera.filippi.org/stats.php?guid=1282308401&type=2&version=0.98&swversion=1.7.5186&uiversion=7 response:
Not Found
HTTP Error 404. The requested resource is not found.
<0x6d24f520>
