Has anyone gotten the PTK5507 touchpad to work with label broadcast? The Envisalink3 was definitely installed before I created the labels.
I’ve renamed all of my zones manually… then noticed label broadcast works with some of the other panels, but not necessarily this one and tried it. Didn’t seem to do anything.
I also did NOT set the manual label variable yet.
I also noticed that the vera doesn’t pick up zone events for my zones, and I’m guessing this is why.
I’m guessing I should make a backup, delete the panel, and try again?
My zones are labeled on my PTK5507, but I named them at the panel level with the DLS software and they transferred my 5507 and my older keypad.
I don’t think the EVL3 supports label broadcast like the IT100 does anyway, so Vera will not pick them up anyway (unless you had an IT100). This may have changed with the EVL3, since it has more memory that the 2DS, and the memory was the constraint that stopped that feature being added originally.
That said, your zones should update anyway, so if this isn’t working then you have bigger issues.
[quote=“rrauenza”]Has anyone gotten the PTK5507 touchpad to work with label broadcast? The Envisalink3 was definitely installed before I created the labels.
I’m guessing I should make a backup, delete the panel, and try again?[/quote]
Last checked the EVL3 still does not support zone labels.
Once you add a zone you must set the zone attributes, e.g. allocated to a partition. If they are not set, they will not be available on the other keypads to accept label.
If you are utilising DLS, uploaded from the panel and hive it run the check which should identify if you have not set the attributes correctly.
I was a little ambiguous:
I meant broadcasting FROM other keypads supposedly works with the vera, but apparently not from the PTK5507. I think I mistakenly implied I couldn’t broadcast to my other keypads – I only have one, the PTK5507.
So I now get events to my zones now that I re-added the panel to the vera. I didn’t rename the zones manually yet, either.
Sounds like I should just set the manual label flag and rename them on the vera.
[quote=“rrauenza”]I was a little ambiguous:
Sounds like I should just set the manual label flag and rename them on the vera.[/quote]
They underlying issue is not the PTK5507, but rather the EVL3 does not accept zone label s and therefore, they are not displayed in you Vera. I asked in the EVL forum ages ago whether or not they were going to add this in the future and they never committed to this and where at the time focus on firmware to add the other brands. I only recently checked and as far as I could tell they have not included this but I currently do not have it operational.
Yes, it is the way to go manually set Vera zones labels.
What is kind of ironic is that you can change the labels themselves in the envisalink3’s own web interface:
But vera doesn’t see them.
That is because you are not modify the data on the EVL3 but on their site (offsite) which effectively translating the zones to labels definitions you input. This is the same process you would be doing on your Vera by recording the labels.
