Prowl iOS notification question
Not sure if this is the right place to ask this question but i hope someone knows the answer here…
I have prowl installed on my iphone 4s and on my ipad mini. (I use the push notification plugin) On the iphone i get prowl notifications like on pic1, on the ipad mini like pic2. I would like to have the same style notification on the ipad as on the iphone. Is that possible ? I have not found anything in the settings to change that, but there must be a possibility ?
The style that an iOS alert takes on is controlled not through the app itself but through Notification Center, which is in the Settings app.
To get the iPhone-style bubble you need to make sure that “Alert” Notifications are enabled.
Thanks. I thought it had to be on the iphone/ipad somewhere. Will try to find it on my ipad tonight.
I have set my iPad notification settings identical to my iPhone on my iPad. On the phone, when the lockscreen is on, I just get a notification from notification centre, and the screen switches off again after a few seconds. On the iPad, I get the full screen prowl app, which stays on until the battery is drained. So the settings in prowl and in notifications in settings are identical, but the behaviour of the two devices is very different. And it is quite annoying when you pick up your iPad and the battery is flat… Especially as it is dedicated to controlling my av system and my Vera.
Any ideas ? I have been trying for a while now and I cannot find it, and I am normally quite good with iPhone/iPad…
