Howdy,
I have about 8 device properties that are extracted from a multi-virtual-switch. The properties represent the switch states and they are all 0 or 1.
A few questions:
Do changes in the property value trigger a condition to be re-evaluated? Things like normal triggers on devices clearly do, but it wasn’t clear to me if properties are ‘monitored’.
When writing a condition that just references a property, what is being considered if I just reference the property name in the condition? For example, if I have a property called MODE_HOME, what is the difference, if any, in what is being tested for in the condition “MODE_HOME” vs “MODE_HOME != 0”?
Does the ‘repeat?’ flag on a condition do anything when the condition is entirely made up of device properties?
I ran into a looping situation this morning where two conditions kept running back and forth. But the underlying device property wasn’t changing so wasn’t sure why they kept re-evaluating.
Thanks!!
Gerry
