Proper Testing Scenarios
Hello Everyone -
I’m starting to play around a bit with my Vera 3. Because I don’t necessarily want to purchase a bunch of stuff until I grow my capabilities, I’m trying to test up a “zTest Room” of sorts that lets me play around.
I do have an Intermatic Dimmer Module that I can use as a “light” but what if I want to simulate switching, motion, etc?
I found a “virtual switch” plugin that seems to do the trick but what about the “load” side? Is there a “virtual light”, for instance?
Related, I’m trying to tie this “virtual switch” directly to the module. So that when I turn the switch on, the module goes one. Likewise, when I flip the switch off, the module goes off. Do I really need two separate scenes (one for “on” and one for "off) with the appropriate trigger from the virtual switch?
Instead of two scenes, you could use PLEG to trigger the light(s) going on and off when you flip the virtual switch. You will have two conditions, and therefore two actions.
Conditions:
VirtualSwitchOn
Not VirtualSwitchOn
Actions:
Turn Light(s) On
Turn Light(s) OFF
[quote=“Bulldoglowell, post:2, topic:179351”]Instead of two scenes, you could use PLEG to trigger the light(s) going on and off when you flip the virtual switch. You will have two conditions, and therefore two actions.
Conditions:
VirtualSwitchOn
Not VirtualSwitchOn
Actions:
Turn Light(s) On
Turn Light(s) OFF[/quote]
MUCH cleaner! Thanks! I have this working but don’t really understand why. :slight_smile: Is the “VirtualSwitchOn” a status value that is returned from the plugin?
EDIT: sigh nevermind. This is the name I gave the input. I’m learning here…sorry :slight_smile:
so, you are good now?
Define “good”. ;D Yep, it looks like it is working. I’m working in another thread on getting my motion detector(s) working and would like to use a virtual switch in place of the motions. This will allow me to test the logic without being in front of the motion sensor.
Thanks for your help.
